I recently purchased insalled vdj pro 6.0.8, everything works fine except sonique/slideshow, Sonique will not display anything no matter what I do, Slideshow will not display bitmaps either. I read the post about DX and VC service packs. I installed them both on win xp sp3.
Please help..
Charly.
Please help..
Charly.
geposted Tue 04 May 10 @ 2:37 pm
Yes! the software comes with an empty sonique folder..then you go to downloads section and download (a winrar zip file) the certified pack somewhere in a new folder under downloads. then copy paste the folder pack into that VDJ \video effects\sonique folder and you shoulsee them when you open vdj. hope that helps! and you can PM me, i got some more!
geposted Wed 05 May 10 @ 5:10 am
@takabron, take a look at these I made a couple of year back, it may help you.
or read this if the vid was a bit grainy...
Go into config > choose video tab > go down to the bottom right drop down window and select sonique, to the left make sure you tick the box, come out of config and select effects > select video tab > select sonique > select/click on activate > select open > this is where you go to where you have your sonique folder, now open the folder and double click on a file, this will now run your sonique effects. you can now play with the two sliders for the type of effect you want. slide show delay will give you how long each effect will run for and the transparency will let you fade the soniques over other effects like a video, show logo etc...
N.B If you have the time go through your individual soniques and delete the crappy ones, saves getting them up on the screen.
hope it helps.
geposted Wed 05 May 10 @ 6:00 pm
