When I use the sound card as a single output the sound is fine, when I use it as Headphones and 2 cards, the headphones from the mac are fine, the FireStudio sound is VERY distorted. I've tried every setting in the FireStudio control software, all of the known settings in the Cue config and in the Audio system prefs. Anyone else having an issue like this?
THANK YOU!
THANK YOU!
geposted Wed 05 May 10 @ 4:33 pm
Ok this is annoying as hell... While running a brand new Macbook pro I can not get my Firebox to run in any other setting besides single output... As soon as i split to 4 channels, i get digital noise and distortion... Can somebody please help fix this????
Apple says its a Presonus problem, and Presonus says its Apples problem...
Intel Core i7
4GB Memory
500GB hard drive1
SD card slot
Built-in battery (8-9 hour)2
Intel HD Graphics NVIDIA GeForce GT 330M with 512MB
PLEASE HELP!!!
Intel Core i7
4GB Memory
500GB hard drive1
SD card slot
PLEASE HELP!!!
geposted Fri 07 May 10 @ 11:20 pm
Try using the 4 output card setting instead of the 2 soundcards setting in the sound config
geposted Sat 08 May 10 @ 6:43 am
It doesnt work... Audio is fine in single output mode, but as soon as you try to split, it all turns to crap.
geposted Sat 08 May 10 @ 11:01 am
plese post a screen shot of your bad settings.
geposted Sat 08 May 10 @ 12:03 pm
geposted Sat 08 May 10 @ 2:01 pm
my friend overnighted me his Firebox card. It works on his mac in Cue 6.0.7 and 5.2.1. On mine it doesn't and the only difference is that mine is the new mac that was just released 2 weeks ago
geposted Sat 08 May 10 @ 2:04 pm
Have you tried to make an aggregate device yet?
geposted Sat 08 May 10 @ 8:21 pm
No, never heard of doing that... Besides, if i dont have to do this on an older Mac, why would i on a newer machine? Weird thing is, its only VDJ/Cue that i have this problem... The other VJ/DJ software works fine...
geposted Sat 08 May 10 @ 9:11 pm
