Hey guys, I've been trying out the trial Pro version to see how the DVS works.
I only have one turntable, so I'm trying to use single timecode mode.
The problem is....
The pitch resets to zero on the currently playing track when i switch the timecode to the other deck.
This only happens when Disable Pitch is selected under timecode debug.
If I turn pitch control back on, it simply takes too long for the software to recognize a stable and accurate pitch.
It takes about 20 seconds to stabilize.
This pretty much makes the DVS feature unusable, please help me!
Thanks
The problem is....
Thanks
geposted Thu 06 May 10 @ 8:10 pm
Hello,
I could help you with time code use and settings, but what is a DVS? Are you using Timecode CDs? Are those VirtualDJ timecodes or Serato time codes?
geposted Sat 08 May 10 @ 12:17 pm
DVS = Digital Vinyl Simulator
Using Serato CV02 vinyl.
geposted Sat 08 May 10 @ 6:30 pm
I'm seeing the term DVS pop up everywhere now - Even American Audio are using this terminology: Digital Vinyl System is the most common explanation.
Don't see how "Simulator" could be correct that would be AVS - Analogue Vinyl Similator which is what timecodes do...
Roy
Roy
geposted Mon 10 May 10 @ 5:11 am
