i bought myself a pair of icdx cdjs already own a hercules rmx i want to to be able to control the cdjs through the hercules rmx do i need to timecode them? what i want to do is run the cdjs into inputs on mixer run 1 &2 output to amp and run output 3 & 4 into line in on my soundcard on pc ive tried the cdjs seperately plugged straight into amp and they work fine i just need help setting up this setup thank you :)
geposted Fri 07 May 10 @ 1:43 pm
can anyone help? thanks
geposted Sat 08 May 10 @ 5:03 am
Hello,
Well iCDX are natively supported by VirtualDJ Pro. So my advice is to use those as midi controllers and remap RMX to do other actions that are not currently do by iCDX, Faders for example.
If you wont have an iCDX but a regular cd-player, then you may need cd timecodes and rmx to be use as your timecode interfase. This is not necessary in your current configuration.
Enjoy, you have good equipment to play with VirtualDJ Pro directly. Install Numark iCDX drivers in your computer (please check in Numark website and install latest drivers found in there). After you install this drivers then connect each iCDX to your computer in a USB port. First connect one iCDX and wait until it is fully installed in your computer OS. After that connect the other iCDX in another USB port. Now open VirtualDJ Pro and you are ready to play with your iCDX
If you don't have enough USB Ports, buy a USB HUB 2.0 with 4 USB extension ports. You can plug this one in your computer and iCDX in USB HUB ports. Would perform well.
geposted Sat 08 May 10 @ 11:09 am
