Has anybody experienced strange picture artifacts when mixing videos? Please take a look at a screenshot http://j.imagehost.org/0285/VDJ.jpg It appears when two videos are played simultanously and I start scratching one of them. Everything works smoothly, only this strange pixel noise appears for few seconds sometimes.
I use ATI Radeon HD 3450 MXM II with Dual Core and 2 giga ram. It is realy annoing as I have already switched from previous NVidia card that was causing video freezes.
geposted Fri 07 May 10 @ 3:51 pm
I have exactly the same problem with my new laptop; a hp with ATI 4330HD (tested with VDJ 6.0.8, 6.0.7, 6.0.5).
Never had this before with older laptops (even with another ati graphic card ATI 1250).
I have bought a new and powerful laptop to have better results and i can't use it.
If someone has informations about it...
PS: I use windows xp
geposted Fri 07 May 10 @ 5:43 pm
I have tried HD 4330 on Windows 7 and it worked perfectly. Now, with HD 3450 I use Windows XP and have this problem. So, in my opinion it seems to be related to the operating system...
geposted Sun 09 May 10 @ 7:55 am
Old problem... update to the latest directx. Problem should be resolved after that. Had that prob 2 years ago. I believe those vid cards need minimum directx 10.
geposted Sun 09 May 10 @ 1:23 pm
You will need a higher OS than XP to run that DX10 card. Win 7 or Vista.
geposted Sun 09 May 10 @ 5:12 pm
If I understand, I can't have a good result with a ati HD 4330 with XP (because i can only use DirectX 9).
And, because i have another notebook with XP, I don't want to install windows 7 (with wich I know, I can install DirectX 11).
So, is there a way to solve my problem ?
geposted Mon 10 May 10 @ 7:36 am
