Hello, do you know any effect that can :
1. Add a kick to the music: like i press the effect and the music stops for a nano second and starts again like a kick
2. Make a loop but the music continues. It's not over loop, what i want is to make a loop but when the loop finishes the music continues in the part of the song that woud be playing if I didn't make the loop
Know what I mean?
Sorry if I sound confusing. :)
Know what I mean?
geposted Sat 08 May 10 @ 10:17 am
I think this is what your looking for, https://virtualdj.com/addons/581/LoopOut.html
geposted Sat 08 May 10 @ 1:10 pm
Almost!
The thing s, when I cut the effect off it was supposedt to resume the song in the time when it would have been if I didn't used the effect.
In the effect you're talking about, when I stop the effect, it resumes the song in the second i started to use the effect.
Know what I mean?
Know what I mean?
geposted Sat 08 May 10 @ 3:22 pm
You have to go in and config it to how you want it to work.................didnt you read the description, lol............heres what it can do
This is the LoopOut plugin, but with a few new features:
- new GUI (not compatible with 800x600 skins);
- option to keep the song playing after the LoopOut (instead of stopping it);
- song will continue from the point where the plugin was started (instead of continuing, as before).<hr>
<b>UPDATE AUG 20:</b> Bug with the point where the plugin was started corrected.
This is what your lookin for.
geposted Sat 08 May 10 @ 3:39 pm
