I am wondering, haven't tried it yet which is why I am asking, if it's possible to use multiple midi controllers simultaneously with multiple VDJ instances running?
I haven't ever tried this but I understand that I can run multiple instances of VDJ at the same time on the same machine AND have them linked, correct?
What I would like to know, before I try and jack up my system, can I use a DMC2 controller to control one instance and then use my Denon DN-S3700's to control the other? I use my 3700's as the primary control and instance and would like to use the other instance, controlled by the DMC2, to drop in samples, loops, drops and sweepers AND have them linked so they'll sync up ton the tempo of the working decks.
Does this make sense AND can it be done WITHOUT negative effects to my system?
Thanks in advance.
Thanks in advance.
geposted Sun 09 May 10 @ 2:35 am
anyone????
geposted Mon 10 May 10 @ 11:19 am
