I want to send separate signals from laptop to each channel on this mixer. If I use USB from computer to mixer, do I need 1 cable or 2? What is the configuration in VDJ? Thanks.
geposted Sun 09 May 10 @ 3:00 am
To all of those who want to use a laptop with a USB mixer, here is what I discovered. Please share this with the VDJ community.
1. Under Config, select External Mixer
2. Select 2 cards + USB
3. The left side USB will go to Channel 1 on your USB mixer, the right side USB will go to Channel 2
4. Very important that in the 2 boxes for output, choose Primary Sound Driver (top box)
5. In the bottom box choose Speakers (USB Audio)
This set up will allow you to use 2 USB cables, and have the decks go to separate USB channels on your USB mixer.
geposted Thu 13 May 10 @ 10:01 pm
