how do i make the automixer work if i pressed num1 ?
how do i turn off the volume in deck 1 or 2 ?
geposted Sun 09 May 10 @ 10:12 am
(1) Map the key to either automix (To toggle automix from playlist on/off) or mix_now to mix across to the song on the other deck.
(2) Use either deck 1 volume 0% or deck 2 volume 0% - Use 100% to turn it back up to max.
geposted Sun 09 May 10 @ 3:21 pm
