I had my first gig using the Ns7 and VDJ in a sweet 16 last night. I was on a high end pc that works very good with vdj audio and video. I bought an extra speaker to use for the mic because ns7 mic does not work in vdj and when I opened serato itch to get the mic functional vdj was very glitch-y with pitch and start button were unreliable. It started great; i was mixing video and audio using a projector for the video. Then vdj stopped recognizing the Ns7. I decided to restart the entire computer because I did not want to have the same problem again. Everything was fine again until the pitch went crazy; slow song was fast, fast was slow; I had to move the pitch slider up and down to restore the pitch. I really love using VDJ but I cannot short change my customers and lose potential customers by using this software live. I will have to either use the hercules rmx which works perfect with vdj or use the Ns7 with Serato itch. I am just hoping a new update of vdj with fix all issues with the ns7.
geposted Sun 09 May 10 @ 11:38 am
What version of VDJ you use?
System spec.? (driver ver. , 32 or 64-bit system, XP or Vista or Win 7, CPU, grafik card...)
If you want help, we need to know this things.
Regards Tjeck
Regards Tjeck
geposted Sun 09 May 10 @ 1:32 pm
I just did a test run at my house and everything worked fine. I realized that the problems i was having at the gig was due to my fault. I did not check out my settings and deck to was matching the bpm of deck one. I apologize for posting the initial post.
geposted Sun 09 May 10 @ 5:39 pm
No problem:-)
geposted Mon 10 May 10 @ 4:39 am
You've probbaly just helped others with the same issue in the future... Good post ;-)
Roy
Roy
geposted Mon 10 May 10 @ 5:24 am
