I would really like to add one of these to my setup, they look awesome. I was wondering how this would function with my RMX or if it would work with VDJ. Has anyone used one of these before?
geposted Mon 10 May 10 @ 12:14 am
I use a nanoKontrol so I assume it would work with VDJ, not sure though. Check the download section and see if they have a mapper for it.
geposted Mon 10 May 10 @ 12:36 am
We finnished the final version for the Numark NS7 and I just started working on this today. I am not sure how I will map it yet still in the "thinking about it" process.
What is neat abot the KP3 is that you can customize the outputs without having to use a midi translator like BOMI. Because it is fully programable (but this is what also makes it difficult) I think what I will do for the first release is use "Program 1" which is a default program.
DJ Esco
(832)798-0000
DJ Esco
(832)798-0000
geposted Fri 03 Dec 10 @ 2:40 pm
