Hi guys,
Can anybody give me an idea as to which external soundcard to use with dj software. My internal soundcard is fine I just need a second card to cue and play the other deck.
Thanks
Eddie.
Thanks
Eddie.
geposted Tue 11 May 10 @ 9:42 am
A 2 stereo channel dedicated DJ card such as Numark DJIO or Native Instruments Audio 2 DJ will give you the best results.
geposted Tue 11 May 10 @ 1:07 pm
I assume your using a laptop?
in that case I would recommend getting an external soundcard that can handle all your audio output/input needs..
yes, VDJ can use the internal soundcard on your laptop, but its not ideal, and why wear out the little 1/8" connector on the laptop?
Do you want to connect the headphones directly into the soundcard?
geposted Tue 11 May 10 @ 3:06 pm
No, I want to connect the headphones to my Numark cd mixer . . .
geposted Tue 11 May 10 @ 5:15 pm
If your mixer has 3 line input, you might want to consider a sound card with 3 stereo channels output (6 analog output), then you can use the third channel dedicated for the sampler..
Otherwise just about any 2 stereo (4 analog output) soundcard will do fine..
http://cgi.ebay.ca/ESI-U46DJ-U46-DJ-USB-AUDIO-INTERNFACE-SOUNDCARD-/260589777309?cmd=ViewItem&pt=AU_Pro_Audio&hash=item3cac5c719d
Probably the easiest to get (and pro + less $$) is the numark DJIO
geposted Tue 11 May 10 @ 5:37 pm
Guys, thank you for your help.
geposted Wed 12 May 10 @ 3:30 am
