Forum: Music discussion
Topic: VDJ Shoutcast echo..
I have searched, but cannot find an answer.. I also found another user that had the same problem. IT would be great if SOMEONE could help.
I can broadcast just fine with the virtual dj (byitself no shout or ice cast) and also with just winamp (using shoutcast) I can also use virtual dj and broadcast through winamp(using shoutcast)the problem is when I try to use virtual dj and shoutcast. After a few minutes I tend to get an echo that after about 20 min or so it more like the same song being played just a second or two later. now this is only when it's being broadcasted via shoutcast. On my end it sounds great. Can someone give me some insight on how I might be able to fix this?
geposted Tue 11 May 10 @ 1:26 pm
