I've added 'record sample' (and play sampler) to one of the effect button on my hercules RMX. This works fine, but it only records 4 beats and I would like the default to be 8 or 16. is this possible
geposted Tue 11 May 10 @ 1:41 pm
Hi! Just Make A Loop Of The Time What You Want. In The Sample Option, You Can Also Make It Play In Loop
geposted Tue 11 May 10 @ 1:42 pm
Could you be a bit more specifik. When I press the rec sample key, it only will record 4 beats. how van I change that?
geposted Wed 12 May 10 @ 8:33 am
1) make the desired loop length on your deck (hit 8, 16, 32 or other length loop button)
2) hit sample rec
It will then record the loop you have active on deck :)
geposted Wed 12 May 10 @ 9:20 am
