Is there a way to define The Video Effect Slots like the Effects?
Example..
video_fx 1 or video-fx 2
and video_fx 1 select and video_fx 2 select
%videoeffectslot1, and %videoeffectslot2
I need these commands to create a VideoFx pannels with 3 banks of Fx. You need to see more than one VideoFx if is activated or not. At the same time Showlogo, BoomAuto and maybe negative could be activated together.
Example..
geposted Tue 11 May 10 @ 6:31 pm
There is no slots for video effects. The 16 slots ae only for sound effects
geposted Wed 12 May 10 @ 4:03 pm
@djcel, is there a certain reason you cant have the slots for video or is just that its not part of the skin makin process? Just curious thats all (I have no clue how these skinners do it, lol).
Thanks for your time
Huey
Huey
geposted Wed 12 May 10 @ 4:43 pm
At the moment there is a limitation in the VDJ Script language. Actually there are no such verbs to use. Hopefully they will be added in future update.
geposted Wed 12 May 10 @ 5:02 pm
Ok that make sense. Thanks
geposted Wed 12 May 10 @ 10:49 pm
