I did search, but i couldn't find any relevant information to my issue
What i want to be able to do is control 4 decks, with two controllers. We would be using two DJ Console RMX controllers, on my MBP running 6.0.7.
Is this possible? I dont want to have to use Traktor.
Thanks
John
Thanks
John
geposted Wed 12 May 10 @ 2:08 am
Sorry, it is not currently possible to do that - Both controllers would operate decks 1 & 2 of VirtualDJ if connected simultaneously.
If you ran two instances of VirtualDJ, then both controllers would control decks 1 & 2 of both instances.
VirtualDJ does not currently support 4 decks in a single instance, but in a future version this might be possible.
geposted Wed 12 May 10 @ 12:38 pm
Ok. Thanks for the response.
geposted Wed 12 May 10 @ 1:42 pm
