hi
Just got Evolution UC33E (very rare since been discontinued, anyway).
When both Hercules RMX and UC33e ON (powered) same time while vdj open, when I want to close vdj, it freezes.
If UC33e turned off, all is ok, it closed just fine.
Someone has a solution? I need both powered same time.
Thank you
Thank you
geposted Wed 12 May 10 @ 7:16 pm
Have you tried changing MIDI channel for the UC33e ?
You are using the most recent drivers for everything ?
geposted Thu 13 May 10 @ 11:37 am
I know I have latest drivers for Everything I own.
How do I change midi channel ?
geposted Thu 13 May 10 @ 1:56 pm
I think the UC33e should have a control panel/software of some sort where you can modify the settings for the device.
geposted Fri 14 May 10 @ 12:26 pm
***RESOLVED TOPIC***
First - You can change midi channel of Hercules Rmx :
Start - Control Panel - Hercules DJ Series (aka Hercules Control Panel) - Advanced
Midi Channel for controls = Change number to preferred channel
(Most Device use channel 1 as default)
(New channel should not cause any interference otherwise there's already a device using it)
Second - You can change Evolution Uc33e midi channel :
Start - M-Audio - Enigma - Import Device setting (down arrow)
View - Control Editor - Control Details - Channel
Change number as preferred
Click Extra Variables - Global Channel
Choose same number from ''control details'' = channel
Use ''X'' marker to close Editor
Use ''Up Arrow'' to send data to device
Wait until Sysex complete
Close Enigma
Third - Primary Problem
If you're using an USB Hub don't use conflicting device same time on same usb hub.
I use an USB port from laptop for Hercules RMX.
UC33e plugged into usb hub.
Follow third action it should solve your situation.
Close Enigma
geposted Wed 26 May 10 @ 8:51 am
If you change the default MIDI channel of a natively supported controller then VirtualDJ may no-longer be able to detect that controller.
geposted Wed 26 May 10 @ 1:22 pm
