Hello, this question will probably sound a bit dumb but basically i just purchased virtual dj. when i first installed it i was able to use the tab key on my keyboard to shift between sides and use the space bar to play songs. for some reason it doesn't work anymore. I was wondering if anyone knows how i can set those keys to perform those functions again.
sorry if my question is really dumb but i would really appreciate any help.
geposted Thu 13 May 10 @ 3:27 pm
Try shutting down VDJ then restart and see if it works, if it works try to remember or write down the steps in which this happens again, If it does, then put in a support ticket with the details and register your copy.
PS you may have to reboot...
Good Luck
Joey...
Good Luck
Joey...
geposted Thu 13 May 10 @ 7:35 pm
