Alright, I've tried and tried to find information on how to get all my equipment working right but here's my situation:
I've got 2 Numark TT200 Turntables
2 (Red) Serato Timecode Vinyls
FSOpen
Gemini PS-121-x (2 channel mixer)
I've got my turntable RCA cables going into the input 1 of FS2 on the output 1 I have RCAs going to my mixer's PH line and from the FS2 THRU i've got RCAs going into the LINE connectors. When I go to the config of VDJ and switch it to timecode vinyl and it reads it (says operating at 100%) and I can move the digital song with the vinyl but it makes me use the ScratchAmp output and I've tried different ways but I just don't know how to get sound to play. PLZ help!
P.S.
I'm using KRK Rokit monitors that have a 1/4" plug but I've also got an 1/8" adapter....Soooo, how would I go from there to sound output??
FSOpen
P.S.
geposted Thu 13 May 10 @ 10:33 pm
This is how your setup should be. The turntable outputs should be going to in1 (input 1 for the first) and the other turntable on input 2. The OUT1 (Output 1) from the scratchamp goes to the input channel 1 (LN1) of the mixer and the 2nd output (OUT2) of the scratch amp goes to the second input of the mixer (LN2). After that where you see the switches on top marked ph1 LN1 and ph2 LN2,ensure that they are both on the sides with the LN as shown in the picture below. Since you're using the Krk Rokit monitors just buy a double Rca cable and have it coming out from the Master output of behind the mixer to the Rca inputs of the Rokits left for 1 and Right for 2. In vdj go to config,sound setup, change the inputs to timecodes,soundcard to asio or scartchamp (depending on what pops up) and outputs to external mixer. Trust me you can't get it easier than this. You didn't say which Rokits you'rew using I assume it is 5.
geposted Fri 14 May 10 @ 10:47 am
Rokit 5 is what Im using..thanks a lot man, that helps me out a lot!
geposted Sun 16 May 10 @ 2:49 am
You should add this to the wiki.
geposted Sun 16 May 10 @ 11:15 am
