I am trying to purchase equipment on a bi-weekly basis as I get paid and I need to make sure my money goes a long way & I purchase the right items.
After buying the Hurcules RMX and then just upgrading to VDJ Pro, what would be the next time you would get? I have no speakers so I was considering getting some powered speakers next then maybe some lighting? What would you do?
geposted Fri 14 May 10 @ 10:37 am
I would say a Korg nanoKontrol for your effects, here check it out, http://www.djtechtools.com/2008/11/23/korg-nano-reviews/. There are 3 different kinds, I've only used the Kontrol and it is badass!! It has 4 different secnes which means you can map 1 just for video effect, the other just for samples, the other just for sound effects, you get the picture, lol! Anyways check em out.
Huey
Huey
geposted Fri 14 May 10 @ 7:12 pm
i would just go for the necesary items right now(decent speakers,decent headphones...)
i mean that's what you need...
having more effects is always nice,but i suggest you get the very necesary first and the luxuary next :)
also,check if you can use the nano effect controllers(on the vdj forum)
i could be mistaken but i thought with the rmx you could only put the effects on the active deck(via the master)
but check it out first will ya,i could be mistaken :)
geposted Sat 15 May 10 @ 4:12 am
thanks, I'll look that stuff over.
geposted Sat 15 May 10 @ 7:45 am
Yeah I never thought about that cause I'm not a moblie dj so I dont need sound. But with the Nano's you can map them to work with either channel, deck 1 effect active or deck 2 effect active. Unless theres some limitations that I dont know about but I doubt that cause its pretty powerful.
geposted Sat 15 May 10 @ 12:30 pm
u planning to use turntables?
geposted Thu 20 May 10 @ 3:31 pm
Don't forget quality cables, its something many people neglect.
Maybe an ipod or cd player for a backup. Computer upgrades, if any are needed. And if you have to, save your money longer for a good set of speakers, its worth it in the long run.
geposted Fri 21 May 10 @ 3:09 am
