Three Displays
I have a display for karaoke and a projector.
My karaoke display is a wide screen and the projector isn’t.
I am currently using a splitter and it can be real buggy when I go back and forth (on different jobs), from using only the projector to using the projector and the karaoke monitor.
So I added another video card to my system.
In Virtual DJ I am only able to select one TV output, is there any way to select two? Is there a skin that will do this?
Thanks,
Glen Conaway
Thanks,
Glen Conaway
geposted Sat 15 May 10 @ 10:23 pm
Ok I found a solution,
I configured multiple monitors in the display settings by duplicating the desktops on two of the monitors, I will swap out the widescreen karaoke monitor with a regular monitor. My goal is not only to make it work, but also to be able to quickly change configurations for different applications. It’s no fun setting up for a job and having to spend allot of time getting things to work.
geposted Sat 15 May 10 @ 11:28 pm
