Hi.
I have already search the forum, but i haven´t found help for my issue.
I've downloaded the cut effect, PC version, and after run the exe but the effect does not install.
Anyone knows what's wrong?
I´ve also some effects in the effects folder and they are not recognized.
The effects folder is C:\Users\USERNAME\Documents\VirtualDJ\Plugins\SoundEffect
Thanks in advance.
Thanks in advance.
geposted Sun 16 May 10 @ 2:07 pm
Maybe a bad download, try to download and reinstall it.............Or it could be that you have "LE", I think you might be limited with that but I'm not for sure about that. Idk cause Ive never had troubles before. Sorry I couldnt be more help. I'm sure someone will chime in and clear this up though. ;-)
Huey
Huey
geposted Sun 16 May 10 @ 3:01 pm
