CAN I HOOK UP MY TURNTABLES TO THE RMX AND BUY A VIRTUAL VINYL RECORD AND USE THE RMX AS A INTERFACE INSTEAD OF BUYING THE INTERFACE BOX FROM NUMARK ITS MUCH CHEAPER I BELIEVE.
geposted Mon 17 May 10 @ 12:19 am
yes with the Hercules RMX as Soundcard you can do Timecode..
you dont need the Numark Virtual Vinyl Box.
Perhaps you look to buy Serato Vinyls - they work for me - better than the Numark ones.
geposted Mon 17 May 10 @ 2:36 am
I don't know about your area, but Serato vinyl is probably the easiest to find around here....as a matter of fact...I think Sam Ash in my area only carries their timecodes. And yes, you don't need the box, I use an RMX and turntables with no need for an external interface/box.
Michael
Michael
geposted Mon 17 May 10 @ 6:55 am
@ bluntfusionn thx for the input bro I'm more of and ol skool DJ, I had the NS7 and had to send back b/c my laptop wasn't strong enough so I exchanged for the Mixdeck and that don't seem to work for me either. I like the feel of vinyl but also like to use the perks of been able to use loopin and effects from VDJ without havin to use my mouse.
@fuskit how those it work for you when you use the RMX with vinyl and I am goin to buy Serato vinyl if I decide to go this route....thx for the input.
More replies plz the more the better.
geposted Mon 17 May 10 @ 8:54 am
it works amazing, check out my setup on my homepage
geposted Wed 19 May 10 @ 9:13 pm
