tried to map the denon 4500 and don't know what i am doing wrong and I screwed it all up. I want the functions keys 1-5 mapped to cue "Jump to" 1-5, the "flip" key to 1/2 beat loop, "time" to 1 beat loop, "memo" to 2 beat loop, "title" to 4 beat loop, "cont/single" to 8 beat loop and "source" to 16 beat loop. The "back" button as the "Video Take" button to fade videos.
Don't know if this is possible but I would like to use "effect 1" to go to the "video transitions" and have the "parameters knob" to scroll through the selections when turned and then select when pressed. I would like to use "effect 2" to go to the clipbank and have the "parameters knob" to scroll through the clipbank selections when turned and then select and activate when pressed. I would like to use "effect 3" to go to my "show Logos" folder and have the "parameters knob" to scroll through the selections when turned and then select select and activate when pressed.
Lastly I would like to have the "tap" button used for bpm sync to the other deck.
The rest can remain the same.
Can anybody out there do this?
Please!
Please!
geposted Tue 18 May 10 @ 1:42 am
You've posted in the wrong section; mapping is no longer a plugin ;)
I'll move this thread to hardware support...
geposted Tue 18 May 10 @ 5:02 am
thanks for letting me know
geposted Tue 18 May 10 @ 6:25 am
No problem. I can probably help you out with the mapping later....
geposted Tue 18 May 10 @ 9:19 am
greatly appreciated...I'm also gonna give it another try tomorrow when I have some extra time.
geposted Tue 18 May 10 @ 6:45 pm
