Hi everyone,
I am looking to purchase some radio mics for my mobile setup. I am looking for recommendations please. I need two mics?
many thanks
Justin
many thanks
Justin
geposted Tue 18 May 10 @ 2:20 pm
Really depends on your budget, what you will be plugging them into, and exactly what you want to accomplish. You can't go wrong with a Shure SM58. You also can't miss with an ElectroVoice RE20. Even a Shure SM7B will do you right. And there are many more...It's really up to you and the application you are using it for.
geposted Tue 18 May 10 @ 3:21 pm
I have a pair of these Skytronic Radio Mics http://export.skytronic.com/product/product.php?s=171.325.
Sound quality is crystal clear and the range is very good. The BNC connectors on the front mean you can add higher gain antennae for geater distance. Rack mount brackets are included.
I got mine from http://www.essexdj.com.
Cheers,
Roy
Cheers,
Roy
geposted Tue 18 May 10 @ 3:45 pm
Kam 1920 is really cheap too and I can recommend
geposted Sun 23 May 10 @ 4:50 pm
