Hi guys
Ive just started to dabble with video djing. Im having problems when I am trying to use video effects for audio tracks. When I am scrolling down the video effects panel and trying to activate them no effect pops up in the screen
A. Do I have them in the wrong location ?
B. Am I opening them incorrectly?
C. Should these files be in a folder in Plugins Folder in C/Documents/virtual dj/plugins ?
D. Should these files be in a folder in Video Effects in C/Documents/virtualdj/video effects ?
E. Should these files be emptied from the extraction folder and placed in any of the above ?
I have tried every concievable mesaure to open the files to no avail. Any help will be massivly appreciated
Kevin
Kevin
geposted Tue 18 May 10 @ 6:20 pm
If you are playing audio files then there will be no video output to apply the video effect to, unless you use Sonique visualisations (Displays moving patterns synchronised to to the beat of the music) or video clips via Clipbank.
You can have Sonique active automatically for audio files by going to CONFIG -> Video and choosing Sonique for Use this plugin for audio-only files.
Video effects should be installed in My Documents\VirtualDJ\Plugins\VideoEffect (The installer included with most video effects will do this automatically for you.)
geposted Tue 18 May 10 @ 6:50 pm
If there just not working (when you click activate) then read this, https://virtualdj.com/forums/95136/Virtual_DJ_Plugins/Plugin_not_working__Controls_not_showing__DX_File_Missing_______Read_this_before_posting_____.html?page=1
Sometimes you just need to add a file or 2.
Hope this helps
Huey
Hope this helps
Huey
geposted Tue 18 May 10 @ 9:24 pm
Superb thanks guys for the help much appreciated
geposted Wed 19 May 10 @ 7:36 am
