Hi
I have the latest version of VDJ and ive noticed after using the KeyChanger plugin the deck I use it on no longer changes pitch correctly (speed up or down) it actually changes it by time-stretching it and it sounds absolutely disgusting and ruins the audio quality of the track no matter wot pitch its played at - it stays this way even when restarting the application..
how can I reset this (and never use the key-changer again :( )
many thanks
many thanks
geposted Tue 18 May 10 @ 7:21 pm
You might be experiencing problems with the keylock..
1st, turn off keylock.. quality come back to normal?
The Keylock in VDJ does work.. but its finicky, and usually requires a bit of fiddly around with different settings to get it to work correctly..
The faster the computer, the better the soundcard (IE: latency etc) , and the better the source material (IE: 320kbps VS 128 kbps), all contribute to how well the keylock works..
geposted Tue 18 May 10 @ 10:58 pm
thanks for your reply :)
I just reset back to original settings which worked.... it ONLY happens after using the key-changer plugin.. used it on deck A and the pitch went on that - then deck B and pitch went on that too... - wont be using that again...just wanted to see wot it done.. I only have 1.6Ghz x 2 (2 x 256kb) , 2Gb Ram and Realtek HD built in sound on laptop - I had to rollback soundcard driver cos it was sticking on the music, works great now though
cheers
cheers
geposted Wed 19 May 10 @ 6:19 am
You will get much better results if you have a powerful computer and are able to utilise advanced master tempo in CONFIG -> Performances
The key changer plugin is obsolete and is no-longer necessary in the latest versions of VirtualDJ - v6 has key changing ability built-in and the default skin has a knob for this. Key changing is used for Karaoke or for mixing in key.
For DJ'ing, keylock is more commonly used, allowing the song to be locked at its normal pitch, but increased or decreased in tempo (BPM) to beat match with the other song without the audible pitch being affected.
geposted Wed 19 May 10 @ 2:48 pm
doesnt it sound awfull though when its time-stretched? - more notcieable when its slower... I would never use that
geposted Thu 20 May 10 @ 5:21 am
set up correctly I can move the BPM's +/- 10% with no loss of quality.
again...
how well it works depends on your computer, soundcard, Music source, and settings.
geposted Thu 20 May 10 @ 10:21 am
Regardless of key lock, you should avoid trying to mix two songs with a big difference in BPM. Gradually work your way up/down in tempo or use an effect (Brake, backspin, etc.) to break up a sudden transition.
geposted Thu 20 May 10 @ 9:47 pm
yeah thanks, I'd rather use a transition than speed a mix up or down... - usually slow record down or let it play out to a long sample then let the new BPM tune start - sometimes the actual build up of songs are good (rather than using em for the mix) ... but you guys already know that :)
geposted Fri 21 May 10 @ 9:09 am
