Hey guys just a quick question
Is there going to be a limited amount of days for me to be able to get access to Virtual DJ on the download page
or will the link always be there incase I need to reinstall it.
Otherwise Il burn to cd.
geposted Thu 20 May 10 @ 5:24 pm
It will always be there for you, but if it gives you piece of mind you can always make a back up.
geposted Thu 20 May 10 @ 5:33 pm
Check the download center link above your software will be there however making a backup of the exe will always give you piece of mind in the event you need it and don't have acess to the net.
geposted Thu 20 May 10 @ 8:44 pm
I would recommend always making a backup. If ever have a problem with a newer release having a backup of the older version in case you need to roll back to an older version.
geposted Fri 21 May 10 @ 1:17 pm
