Hi, Just want to double check before i buy, I'm looking at buying a turntable to go with my hercules rmx. Will these two work together?
Thanks
Thanks
geposted Fri 21 May 10 @ 8:49 pm
They do, but I don't think you can use turntables with the DJC Edition software. You get a discount on pro version because of your DJC license, however.
geposted Fri 21 May 10 @ 9:39 pm
Yes, it will work, I use it every week.....7 days a week. And I am 99% sure you have to be a pro user to use it in this setup (feel free to prove me wrong I don't mind and it would come in handy for later use). But like mentioned before you get a discount on the upgrade from LE to Pro which really pays for itself....to give you an idea, I had just got my DMC2 setup when I upgraded from the LE that came with it to pro. I paid $169 for the DMC2 with LE (new at sam ash as they were trying to get rid of them since numark no longer makes it) and then did the upgrade.....if you do the math I basically paid $19 for my DMC2 and the advantages of PRO over LE/basic are exponential.
Michael
Michael
geposted Tue 25 May 10 @ 7:52 am
