Now that I got your attention....:) I am starting to build a pretty nice collection of videos (VOB format), and I want to save some space on my drives. I would like to convert from vob to mp4. Sense you guys are the experts, can you direct me towards the best app to convert vob to mp4? Thanks in advance.
geposted Sun 23 May 10 @ 12:14 pm
http://www.erightsoft.com/SUPER.html
This is the ONLY audio/video converter you'll ever need, no contest. And, it's FREE. The interface is a bit crowded but once you
paly around with it it's fine. Many presets also.
geposted Sun 23 May 10 @ 3:21 pm
I would prefer meGUI. It's for free and does much better quality videos as the super encoder. Take a look at my Tutorial:
https://virtualdj.com/homepage/jakovski/blogs/3951/Videos_in_MKV_oder_MP4_umrechnen___How_to_convert_videos_to_MKV_MP4.html
Greets, Heiko
Greets, Heiko
geposted Sun 23 May 10 @ 3:25 pm
Greets, Heiko
Greets, Heiko
Does also convert audio files too like Super?
geposted Sun 23 May 10 @ 3:32 pm
Thanks fellas for the quick responses.....time to sit down and start converting...................Gonna take me a whole weekend to do though! ;)
geposted Sun 23 May 10 @ 4:52 pm
or stay with .VOB and get bigger harddrives when you start to run out of space..
geposted Sun 23 May 10 @ 7:30 pm
This is great and converts to and from every format - http://www.avs4you.com/AVS-Video-Converter.aspx
I agree that mp4 is the best format because of its small size and good quality, but with affordable 1.5 TB hard drives currently out there, and with storage space constantly getting bigger, you can just stick with the original .VOB files.
geposted Sun 23 May 10 @ 8:36 pm
TMPGEnc 4.0 XPress - not free but very good.
geposted Mon 24 May 10 @ 9:42 am
I STRONGLY suggest you NOT re-code ALL your videos to Mp4 unless you plan on keeping the original files. More users report problems using Mp4 than Mpeg2. (vob) especially systems with borderline resources. I suggest recoding a group of files first and see how well they perform before converting them all. This way if you do have issues you can go back to your original files. (Recoding back to Mpeg2 from Mp4 is NOT a good option)
R~
R~
geposted Mon 24 May 10 @ 10:07 am
C'mon man with the CHEAP price of Hard drives just buy a big drive(s) and leave them alone!
geposted Mon 24 May 10 @ 4:48 pm
Yea, it looks like I might do better just getting a bigger drive. Thanks for all the input from everyone. I just saw a video at half the file size (mp4) that looked just as good...... But it's a lot quicker to rip to a Vob file for sure! Thanks again everyone!
geposted Mon 24 May 10 @ 5:35 pm
My system stutters vob files. Mp4 never a problem, if I use a vob I am garanteed a stutter and a freeze up.
Just thought I would throw that in there.
geposted Thu 26 Aug 10 @ 10:12 pm
Since the last couple of months.. All my new videos are Mp4 h.264 video quality in 720p pr 1080p.
geposted Thu 26 Aug 10 @ 11:11 pm
I am interested in hi def video,the next step..is there a converter that does HD VIDEO CONVERSIONS,or where can you get them,thanks..
geposted Fri 27 Aug 10 @ 7:36 am
Are you ripping them from YouTube? Or getting them somewhere else?
geposted Fri 27 Aug 10 @ 7:32 pm
I also agree with buying a bigger hard drive instead of trying to convert all your files. Most .VOB's will load faster and as also mentioned earlier, will work better on less hardware.
A 2 Terrabyte drive is pretty cheap nowdays. Just make sure you get two of them and backup regularly of course.
geposted Sat 28 Aug 10 @ 2:07 am
Somewhere else
geposted Sat 28 Aug 10 @ 3:11 am
A lot of you guys are saying "Do not convert VOB, just buy bigger hard drive". What if I want to get rid of black borders and normalize sound? Convert VOB to another VOB?
Or you just don't care how your videos look on the screen?
geposted Sun 29 Aug 10 @ 6:02 pm
Love it: http://www.any-video-converter.com/products/for_video_free/
Free, works great, converts everything with no errors and not in Chinese like Super© .
Make sure you enable interlace and uncheck normalize in the options.
Most of the older videos don't look any better if they are 250mg vob or a 50mb mp4. My new Usher vid's @ 75mb mp4 looks 100 times better than any pre 2003 video in vob format. Also, smaller videos take less time to transfer
thanks,
David
DJ Kavika
thanks,
David
DJ Kavika
geposted Thu 21 Oct 10 @ 8:51 am
