hi i using the version 4.3 and i download the new version 6.07....but i can not confi the timecodes when i conect in the club.with 4.3 is so easy..
and if i try downlad some skin is not possible to instal it say virtual dj not found
geposted Thu 27 May 10 @ 9:37 am
I had the same problem but with VDJ 5.0 to 6.0. I guess the older versions are better...
geposted Tue 20 Jul 10 @ 11:56 pm
The developers spend a lot of time improving this software. You think they sit around and say, "What can we do to screw this software up"? Don't be silly. It may be a good idea to test the upgrade BEFORE you go live. Spend some time speaking with others that may be going through the same issues. Are you saying that out of thousands of users, no one is using time codes with success? Please. All you have to do is ask for help on these forums, and you will get it.
geposted Wed 21 Jul 10 @ 2:26 pm
Can't help you with going from 4.3 to 6.0.7 but I can tell you that you get the error messages because you don't have virtual Dj you have numarks virtual vinyl. I to would run into this from time to time.
Wish I could help more........
Huey
geposted Wed 21 Jul 10 @ 2:52 pm
