Hey guys im trying to get this Multi instance skin, link below, to work with my mac version of VDJ.
https://virtualdj.com/addons/967/Multi-Instance_Skin_variations.html
I copied the zip file from the skins folder on my pc side of VDJ and copied it over to the skins folder on my mac side of VDJ. It opens fine and all but it only opens one instance, as you may figured out I want it to open multiple instances, like it does on the pc side.
for people who don't know what the multi instance skin does, it allows you to basically have more then one window of virtual dj open at a time which allows you to to have more then two decks, its wonderful.
Another probably related thing to add is I did download a different multi instance skin a few days ago and it too only opens one instance. Weird
So how do I get this multi instance skin to work right?
Thanks every body for your help
Josh=?
Josh=?
geposted Thu 27 May 10 @ 10:05 am
Come on I know there are some really smart people out there that can help, any suggestions would be so appreciated. Thanks
Josh=?
Josh=?
geposted Tue 01 Jun 10 @ 4:33 pm
