Topic: Numark Mixdeck - Page: 2
Go to your download center and update to the newest version and then try it.
Let use know what it does, in more detail other then "it doesn't work"
Huey
Hello! Guys, I've been reading through every forum here. I've done it all. I can't even load a track onto the decks. My laptop recognizes the mixdeck, but VDJ 7.0.2 doesn't read my mixdeck. Please someone help.
Do you have the Mixdeck in MIDI mode??
Yes. Midi mode, CH1 and CH2 on PC and Cue Master on Ch1/Ch2. and nothing. I can't even map.
Can you upload a pic of your settings??
hi guys, i have just bought a mixtrack pro, which is a hardware controller, i thought it could do what i wanted but it appears not, anyway I wanted to record my radio shows, mic and hardware, however I cant record onto my software, it says there is a problem with the soundcard. I was hopin someone could help me please
Please open your own new topic rather than hi-jacking an existing one that is not related to your question in any way.
The topic is about the Numark MixDeck, which is a different controller to the MixTrack Pro.
To open a new topic, please click on the pen and paper icon at the top of the forum topic list page.
Also, please use the hardware technical support forums for questions like this: https://virtualdj.com/forums/31/Hardware_Technical_Support.html
default mapping... the eject button is set to swap the deck on virtual DJ so u might want to check that also. make sure on your LCD that you see 1 on deck one and 2 on deck two. if that's correct then the sound card configuration needs to be checked
Hi
I have a numark mixdeck and having problems when trying to play music from my VDJ as the mixdeck switches sides and the faders dont work.
I am struggling to find someone who can help on a Saturday
So My NUMARK Mixdeck Volume Controls Are Crossed. The Decks Play How Virtual Reads Them, But I Can't Get The Volume To Switch. Left Deck Is Controlled By CH2 Gain, Treble, Mid, Low, And The Right Deck Is Controlled By CH1. I've Tried Restarting Everything, Checking To See If A Switch Was Flipped On Or Off, And Nothing Works. Someone Please Tell Me How To Fix This?
Nevermind I Fixed It. Somehow In Sound Setup It Was Crossed. Left Was CH3&4, And Right Was CH 1&2. Switched It Back And It Was Fine.
have you changed the source to "USB MIDI" on the mixdeck?
New Problem Now. So When I'm Using Virtual DJ With My Numark Mixdeck, My Crossfader Works Fine On The Mixdeck, But It Doesn't Move On Virtual DJ. One Of The DJ's I Work With Has The Mixtrack Pro, And His Crosfader On Virtual DJ Moves When He Moves His Crossfader On The Mixtrack Pro. Any Idea Why It's Not Connected?
It doesn't move cause the mixer section isn't MIDI like the Mixtrack Pro.
