I need help...
Is there a way to map the outer jogwheel to function as pitch bend?
With the built in map, the pitch bend function is only possible when the scratch is off and only on the inner jog (with a need to push the jog to function).
I wish to function the pitch bend (freewheel (outer) and the touch scratch (inner) at the same time as the other software possibly mapped for this controller.
Thanks and help appreciated a lot.
geposted Sun 30 May 10 @ 3:47 am
Strange! nobody is using this controller...
Mapper experts might intervene, please.
geposted Tue 01 Jun 10 @ 2:04 am
hey there
i have the same problem and cant figure out what to do right now..
have you found out a solution?
quick answer would be awesome ;)
geposted Fri 21 Jan 11 @ 8:28 am
Sorry bro, no luck on my side...
geposted Fri 21 Jan 11 @ 3:54 pm
sucks :(
tested the controller with traktor le yesterday, pitch bend on outer jogwheel worked just fine, yet it is as far as i know impossible to import the map (tks format somehow) to traktor pro's tsi...
geposted Sat 22 Jan 11 @ 4:42 am
i used many controlls and i have i mix reload but i don't found skin for it......
american audio: found easy
cdj-2000: found too easy
but nowhere i mix relaod >.<
and hey do yo know where i can buy virtual dj pro under of 100 €
geposted Wed 29 Jun 11 @ 4:44 am
Only products that come with VirtualDJ LE or Console Edition included may have official skins available for them (This is included with the LE software.)
Other skins are user-made and contributed by the community: https://virtualdj.com/addons/skins.html
VirtualDJ Pro can only be legally purchased from https://virtualdj.com/buy/ - If you find it for sale anywhere else, then it is an illegal counterfeit or pirate version and you will be wasting your money if you purchase it. The only exception is boxed versions of Numark Cue, which is legally sold in retail stores. You may also find Numark VirtualVinyl still available, but this is a discontinued product.
NOTE: VirtualDJ cannot be sold second hand - Doing so is a violation of the End User License Agreement and if you purchase a second hand version, you will not be able to register it to be able to download software upgrades and free add-ons.
If you wish to purchase VirtualDJ Pro cheaper, then you can upgrade at a discount from any hardware controller that includes VirtualDJ LE or Console Edition: https://virtualdj.com/products/hardware.html - The more expensive the controller, the greater the discount.
VirtualDJ LE with Hercules RMX, 4-Mx, Numark MixTrack Pro, Denon DN-MC6000 and VMS4 will allow you to upgrade to VirtualDJ Pro for $149 instead of the full price of $299.
geposted Wed 29 Jun 11 @ 5:19 am
