I have a laptop and use two external hard drives - one that has karaoke music as well one with MP3s on it (K:). The other has all MP3s (different ones) on it (M:). When I do a search it is not finding the music on the M: drive. When I go to config options and the browser tab, just the C: and the K: show up where the "Check", "Clean", and "Fix" choices are. My M: drive does not show. I have gone out to the folder area and chosen the M: and said "Add to database search" and it still doesn't show up. I'm pretty sure that it used to in an older version. I presently have 6.0.7 Pro installed. I was wondering if this was a bug or something is wrong with my database file? I can search for songs on the folder side of the VDJ screen, but they don't show up in the config tab "browser database" section. Why? Am I doing something wrong? I wanted to update to 6.0.8 or 6.1.0, but I didn't want to wast my time. Any advice anyone?
geposted Sun 30 May 10 @ 11:45 pm
when you go to do a "check" or "clean", VDJ only shows the drives in the drop down list that are available.
So if its connected but not showing up as an option to clean, that means VDJ (and windows) does not recongnize it as a VDJ music source..
When you upgraded to 6.0.7 were ALL your external hard drives connected and showing up in windows BEFORE you upgraded?
What Version did you upgrade from?
VIA VDJ open the "my computer"... does the M: drive show their?
geposted Mon 31 May 10 @ 9:34 am
Correct. I upgraded from 6.0.6. Usually when I have one external drive connected, the other one is as well. I don't remember for sure when I upgraded, but they have both been connected several times since then and I have "added to database search" several times. Yes, they used to show up in the older version. It used to show "C:, K:, and M:" in the options, browser tab.
The drive does show via VDJ and I can search and pick the songs that way, but a lot slower. It's confusing me. I'm not sure what's going on. I was going to update to 6.0.8 or 6.1.0 and see if it still does it.
geposted Mon 31 May 10 @ 2:27 pm
