I have the RMX contorller, and im playing in london.
Im going to be mixing dubstep, along with the virtual DJ i got with the RMX.
I was just thinking, should i upgrade to pro before i play? Is there more features that will make my set any better?
Safe,
Greg.
Safe,
Greg.
geposted Mon 31 May 10 @ 6:15 am
I don't believe that PRO has any increased sound quality
but purely for downloadable skins and effects its worth it. Plus you get a decent discount with the RMX - lets be honest if you're gonna be serious about Djjing you may as well upgrade now rather than later...
up to you though....you may get better technical support and playlist control as well? not sure though.
geposted Mon 31 May 10 @ 10:41 am
hi babe, i've been DJing for Clubs and 2 radio stations here in Brighton (since January)with an RMX and VDJ limited edition and all seems fine. It sounds good, works well and looks cool. i cant ask for more!
i was going to upgrade before i started doing clubs but the system works so well i'm happy to keep this set up for as long as i can.
hope that eases your mind some.
good luck.
XXX
good luck.
XXX
geposted Wed 02 Jun 10 @ 3:39 pm
