I did not find answer to this in the search.
This compatible songs option has never appeared on my VDJ until the other day.
Then it only appeared once,now it is not shown anymore.
Do you need to make some sort of filter for this or is it part of
the program?
the program?
geposted Mon 31 May 10 @ 7:46 am
Maybe you deleted the Filter Folder ?
My Filter is: type="audio" and bpmdiff<=2 and keydiff=0
Greets, Heiko
Greets, Heiko
geposted Mon 31 May 10 @ 9:18 am
I'm not sure what your talking about?
"This compatible songs option "
as above, you can create a filter that looks for songs that are "close" to what you are currently playing..
or maybe your talking about netsearch/musicgroups?
Can you describe what you saw?
geposted Mon 31 May 10 @ 9:39 am
There are 3 filter folders created by default on FRESH CLEAN installs without an existing database.
They are -
Title - Filter
Most Played - top 50 nbplay
Recently Added - top 50 firstseen
Compatible Songs - bpmdiff<=4 and keydiff=0
If you do not have them you can recreate them on your own with the above information.
They are -
Title - Filter
geposted Mon 31 May 10 @ 9:47 am
Nope, never deleted it.
Anyway you guys gave me the info which I will give a try on
Thanks
Thanks
geposted Mon 31 May 10 @ 12:53 pm
Once I have created the folder, how do I add songs to it?
geposted Mon 31 May 10 @ 5:16 pm
The songs are automatically added based on the criteria you've set for the filter folder. For example, if you've made a filter folder to include songs from 90-100 bpm, any song in your library between 90 and 100 bpm will automatically appear in the filter folder. You can't drag and drop songs into a filter folder if that's what you're getting at.
geposted Mon 31 May 10 @ 5:57 pm
Did not know this functionality and already put to work the filter compatible songs ", but would like to improve the filter. Anyone know how do I get the folder contains only songs from the same genre of music that's currently playing?
geposted Mon 02 Aug 10 @ 5:00 pm
the program?
the program?
geposted Fri 19 Nov 10 @ 4:02 am
thanks a million TO CSTOLL for the info on COMPATIBLE SONGS IT WORKS!
geposted Fri 19 Nov 10 @ 4:45 am
Mr. Stoll deserves a raise ......
geposted Fri 19 Nov 10 @ 5:18 pm
uuuuhh Blue eyes .......
can't you just right click on the filter folder icon , i think it's listed right there ..........
geposted Fri 19 Nov 10 @ 5:35 pm
Is there any way to make this (or any) filter folder permanent? My filter folders disappear every time I restart VDJ.
geposted Wed 06 Aug 14 @ 2:21 pm
I have all my files sorted by folders.
I have one folder for disco sound, other to 80's, etc etc etc.
The compatible song filter, shows all files from all folders.
Is there a parameter to set it to display or search only in the current folder?
something like : and folder = same
Zorza
Zorza
geposted Wed 06 Aug 14 @ 3:44 pm
I'm a fool. It was in a checkbox to show filter folders . . .
geposted Thu 07 Aug 14 @ 2:08 am
Try add compatible songs to my virtual Dj library but it don't w
geposted Wed 21 Jan 15 @ 8:57 pm
there is no compatible songs filter in vdj 8. what is Geniusdj for.
geposted Mon 11 Jul 16 @ 6:16 pm
Please read this thread, stay on topic, and check the manual for Geniusdj here, thank you.
geposted Mon 11 Jul 16 @ 6:42 pm
How do I get my compatible songs list
geposted Sat 09 Feb 19 @ 3:30 am
They are -
Title - Filter
They are -
Title - Filter
geposted Sat 09 Feb 19 @ 7:02 am
