Hi. I'm using the latest version of VDJ and the Herclues MK2 midi controller. Today I bought a Behringer cdx700 + 2 x CDJ-100s.
I connected the cdjays onto the line-in channels on the Hercules MK2, I also switched the Herclues to line-in and not phono-in. The Outputs are going to two different channels on the Behringer mixer, and master output goes to my amplifier.
My settings in VDJ are correct as far as I concern. The Hercules soundcard is set to asio, and the timecode settings are correct as far as I have read here in different posts in the forum.
When I load the TCCD in each player and press play when a song is loaded, the song is running crazy, and there is no smooth playback. There is nothing you can do to stop it, and it seems to me that it is something wrong with the timecode cds I downloaded from this site (The ones for cdjs-100 and cdj-200). The cds are burned in WMplayer in 1x, and I have tried burning them twice, with no luck.
Any thoughts ?It is really annoying when it doesn't work.
Thanks,
Steffen.
Thanks,
Steffen.
geposted Mon 31 May 10 @ 5:48 pm
Here are two pictures of the sound setup:
http://home.no/jibvids/square.bmp
http://home.no/jibvids/square2.bmp
geposted Tue 01 Jun 10 @ 1:39 pm
Problem solved!
After a lot of reading and researching I updated my Hercules MK2 drivers (April 2010), and burned two x SERATO timecode cd's on 1x bruning-speed.
My asio soundcard settings are 44.100 kHz 24-bits @ 10ms
Worked like a charm! People saying cdj-100s don't work with timecodes are wrong. Allthough, there are some limitations with the cdj-100s and timecode cds. But things like looping can easily be done in VDJ or with the hercules mk2 mixer.
geposted Thu 03 Jun 10 @ 4:52 am
