I like using the reggae horn.
geposted Wed 02 Jun 10 @ 8:11 am
none
geposted Wed 02 Jun 10 @ 8:12 am
I have grown to love loopout
is there a Video Version ? I have noticed the effect does not look the video...
geposted Wed 02 Jun 10 @ 8:30 am
Oh my yes that's a great idea. Loopout video plugin.
geposted Wed 02 Jun 10 @ 12:37 pm
I use the flanger a lot during transitions, and I find myself playing with the beatgrid occasionally, too.
Just recently started messing around with the loopout, and I can see myself using that more often, as well.
geposted Wed 02 Jun 10 @ 2:24 pm
It will work with video if you tick the box under the video tab that says "Volume Fade to black" or something like that. But you have to make sure you crossfade on the last loop cause the video will reappear. Other then that little flaw it works great! And I have mentioned this in either the plugins page or the wishes forum.
Huey
geposted Wed 02 Jun 10 @ 2:32 pm
flanger til its done 1/2 a cycle then the 1st bit ov beat grid.
oh and flippin double is good too. often do flippin double for 4 beats then finish with the 1st bit ov beat grid...
...i just love to add effects!!!
i want more!!!
XXX
i want more!!!
XXX
geposted Wed 02 Jun 10 @ 3:26 pm
