I'm in the process of mapping my Xone 1D, but I can't seem to figure out the correct command parameter to switch between active decks.
In other words...when I press a certain button, if left deck is active command select deck right is executed and vice versa.
Help please :-)
Help please :-)
geposted Thu 03 Jun 10 @ 1:46 pm
deck active select will toggle to the opposite deck.
geposted Thu 03 Jun 10 @ 3:57 pm
Thanks jpboggis, worked like a charm :)
One other issue I noticed while mapping the Xone 1D were the jogwheels. I got them working fine on normal jogwheel/touchwheel mode, but the scrolling speed is always the same no matter if is spin the wheel slowly or fast. I would like to archieve similar behaviour as with Numark DMC2, i.e. precise scrolling when spinning the wheel slowly and rapid scrolling when spinning the wheel fast.
Apparently this is what the speedwheel mode is for, right? Any idea if the Xone 1D supports the speedwheel mode? So far I haven't been able to make it work like the jogs in DMC2.
geposted Fri 04 Jun 10 @ 9:45 am
