So I just put my RMX on my mac and I have a question. On my PC when I would add a song to a deck that is already had a song playing there would be a pop up window that asked me if I wanted to add this song because there was already a song playing on the deck....now on my mac there is no pop up window...it would accidentally add the song to the deck that id playing and automatically stop the song and add the new one...is there any way I can get that pop up to come up?
Thanks
Thanks
geposted Thu 03 Jun 10 @ 3:42 pm
Im using VDJ.....forgot to add that in there
geposted Thu 03 Jun 10 @ 3:47 pm
This is a security options that should normally be present under OS X also.
I will presume that you are using the latest version (v5.2.2) , as well as the most recent driver for the Rmx (v2.11) ?
geposted Fri 04 Jun 10 @ 6:19 am
go to VDJ options and for the feature "security" make sure it is enabled.
geposted Fri 04 Jun 10 @ 8:47 am
Unfortunately, options are not available with the Rmx LE version of VDJ.
geposted Fri 04 Jun 10 @ 1:48 pm
The full version is worth the $$$. You get so much more in terms of features, and options, that I do not regret the upgrade at all…. As long as you keep your Mac OS system in optimum running condition using the regular maintenance procedures, and Vdj up to date, you should be able to do any gig without fear.
geposted Fri 04 Jun 10 @ 9:07 pm
so if I purchase the full version I will be able to have this feature? I might as well get the full version i have a lot of good thing about it..
thanks everyone
thanks everyone
geposted Mon 07 Jun 10 @ 7:37 pm
Yes. I would do the update. Im not sure if they still give you the discount with the RMX, but when i upgraded, it was only $150. WELL worth the money.
geposted Wed 09 Jun 10 @ 12:27 pm
Yes, the Hercules DJ Console RMX discount is still available.
geposted Wed 09 Jun 10 @ 5:06 pm
great thanks for the help everyone
geposted Sun 13 Jun 10 @ 9:19 pm
