i have just bought a new macbook, and getting used to it after using pc for so long. Ive installed vdj etc, but when i try to open a newly downloaded skin, it says Virtual dj not found. Can anyone help?
geposted Thu 03 Jun 10 @ 3:54 pm
opening the actual skin will not open the program, you have to put the skin in the "skin" folder of VDJ. This can be found I believe if you open your hard drive, select your documents folder, then VDJ, and then skins. Then you change the skin in the options of VDJ.
geposted Fri 04 Jun 10 @ 8:46 am
