I have the following shortcuts:
0: Loop 1 (temporary)
ALT+0 (set cue 10)
2: Loop 4
CTRL+9: Loop 4
I have nothing else set for 0.
Nothing else set for ALT+0
And nothing else to cause Loop 4
Half the time when I press ALT+0, it will set cue 10, but then will also make a loop of 4 beats!
Specifically it happens when I do it like this:
ALT+0: Sets cue 10
Release ALT first, then 0: No problem
Release 0 first, then ALT: It makes a loop of 4 beats
This is minor, but I'm posting it in case the bug in question can lead to bigger issues. :)
ALT+0 (set cue 10)
2: Loop 4
CTRL+9: Loop 4
ALT+0: Sets cue 10
geposted Tue 31 May 05 @ 6:37 am
I actually use this bug in my mixes.
ctrl+2 is set to do temporary effect number 2 on default deck.
when i do ctrl+2 then release ctrl and then release 2, it does the effect number 2, and not temporary anymore.
That is usefull to have less keyboard shortcuts used for 2 different things.
____
P-06
____
P-06
geposted Tue 07 Jun 05 @ 12:57 am
