Will audio8 dj work with VDJ Pro on PC so you can cue track in headphone ? (cuz on mac it wont)
geposted Fri 04 Jun 10 @ 2:36 pm
Yes, it works
geposted Fri 04 Jun 10 @ 3:41 pm
Using external mixer, yes it works easily.
Using the Audio8 headphone out, yes it also works but with a little work around.
Option1
You may set your soundcard option output to Headphone, 2 cards, Master: Audio8dj CH 1/2 out (or any output channels except CH 7/8), Headphone: Audio8dj CH 7/8 out. Remember this setting cannot and is not using asio and most likely you will experience audio drops when using master tempo and a not so very responsive program due high latency.
Option2
Soundcard option output to Headphone, Master: Audio8dj CH 1/2 out, Headphone: Audio8dj CH3/4 out, souncard: ASIO driver: Audio8DJ or ASIO4all (if you have).
On your Audio8 souncard, loop the CH 3/4 out (using stereo RCA) to CH 5/6 IN, press the Headphone source to IN5/6 and adjust the headphone volume to the desired level.
This you can have all your asio settings utilized but without using external mixers headphone output. This will be useful also if you're not using external mixer. And oh yes you can listen also your master out simultaneously w/ the one on cue by adjusting the PH mix over the software or from your controller.
Hope that helps.
Option1
Option2
Hope that helps.
geposted Sat 05 Jun 10 @ 7:56 am
