Hey guys how do I setup my new Deejay Trim with Timecode. I switched from SL1 to the Trim and I'm pretty confused...
So far I can run both timecodes but theres 2 issues.
1.They are slowed down.
2.They play through the same channel.
I'm using Serato time code.
geposted Fri 04 Jun 10 @ 3:39 pm
If you have the timecodes working for each deck and the mix comes out on one channel pair (L&R) when using an external mixer, check in VirtVinyl config menu that your output is set for external mixer.
geposted Sun 18 Jul 10 @ 9:03 pm
You can always take a look at the user manual regarding the timecode configuration and connections:
http://ts.hercules.com/download/sound/manuals/Trim/vdjLE/01_VirtualDJ_6_LE_TC_English.pdf
As for the soundcard configuration , it depends how you intent on using, but to have something similar to SSL, it would be:
- Input : 2 Timecodes
- Output(s): Mixer
-Soundcard: Deejay Trim 4&6
- Output(s): Mixer
geposted Mon 19 Jul 10 @ 6:47 am
