Hi, I recently bought the Hercules RMX and have been very impressed so far! The only problem is that the left job wheel like catches something and makes a noise! No matter what the resistance using the screws under the RMX, it still stays the same and it's as mention only on one of them. I could send it back but everything else works fine, I mean is there anything I can do?
geposted Fri 04 Jun 10 @ 4:57 pm
Nevermind :(
geposted Sun 06 Jun 10 @ 6:26 am
Hello Cricketgd,
1) Is the jog wheel making a mechanical noise (a noise you hear when you turn the jog wheel while the DJ controller is not even connected to a computer) or is it making an electronic noise (a noise you hear in the music)?
2) The screws below the jog wheels are not supposed to change anything in a noise as the adjustment of the resistance is processed via a magnetic field, so a magnetic field should make no noise.
geposted Mon 07 Jun 10 @ 7:12 am
