Ello! I'm a mobile DJ and have been using VDJ for several years with a company. Last year I decided to man up and buy the program for personal use.
Will VDJ will eventually get support for USB microphones? Currently there is no option. I understand there's a latency issue if you plan to use it for live shows, but having built-in support for a computer mic through the main channel would be indispensable for internet broadcasting direct from a computer. I have to use an external program to broadcast so I can use the mic, and as you can probably imagine, it's not exactly ideal. I also don't want to set up my Denon HC4500 and X500 every time I want to broadcast simple shows.
Hopefully this question will be seen and answered by a developer, but I would like to know if computer mic support would benefit other VDJ users. Thanks in advance guys. :)
-Dave
-Dave
geposted Sun 06 Jun 10 @ 12:23 pm
I think you already can use a USB mic with VDJ.
I dont have time today, but do a search in the forums, as I have seen this question before.
geposted Sun 06 Jun 10 @ 7:54 pm
Bamp. I searched the forum, but I haven't seen any definitive answer on this.
geposted Mon 07 Jun 10 @ 5:47 am
geposted Mon 07 Jun 10 @ 10:16 am
The link does not work. does anyone have an update or recommendation for this.
geposted Wed 30 Jun 10 @ 11:02 pm
My blog is set up for Pro users and above to see. I hope too see you purchase a full Pro version, so that you too can read how to configure a USB mic to run with VDJ someday ;^)
geposted Thu 01 Jul 10 @ 6:28 am
Good guide, but how do you work round it with a Steel not RMX?
geposted Tue 12 Oct 10 @ 4:41 am
Simply select which ever sound card your using for the mic. Then run the set up as I laid out. I have set it up with 6 different soundcards now, and they all use the same set up.
geposted Tue 12 Oct 10 @ 6:30 am
