Oh wise ones ov the West, i beseach thee for an answer to my simple query...
Prior to playing out i construct a playlist ov the tracks i'm going to use but sometimes (not always) when i open up the program the list is totally scrambled.
Why oh why oh why, does this happen?
Being a bit Anal, i also write the list down on a scrap ov paper (luckely) so i use this to play tracks in order, but would love to know why it sometimes is scrambled.
I only use the LE version so haven't got all the features that the pro version has, but would still expect the LE version to remember what order i set the tracks...
Please furnish me with the wisdom ov the Wise ones...
Thanx all.
XXX
Thanx all.
XXX
geposted Mon 07 Jun 10 @ 10:27 am
XXX
geposted Tue 08 Jun 10 @ 12:33 pm
Well, I can't tell you much about the LE version. I only had it long enough to determine that I liked the program and then I bought it. But, if it is anything like the full version, it saves your playlist in the order that you build it. So if you want to have your songs in BPM order, you have to sort on BPM before you save it.
geposted Tue 08 Jun 10 @ 2:59 pm
thanx babe. i dont think it is like the pro version... dratts!!! i'll stick with my little bits ov paper for now.
XXX
XXX
geposted Wed 09 Jun 10 @ 11:34 am
