So the VMS4 will capable of mixing 4 channels and it's going to come with Virtual DJ 6 LE.
So is VDJ going to come out with an upgrade to support 4 channels or is the VSM4 going to have 2 extra channels that basically are pointless if you're using it with just VDJ?
geposted Mon 07 Jun 10 @ 11:33 am
How are they pointless?
You can use three of them from VDJ (2 decks + sampler) and still have a channel spare for analogue sources such as a backup CD player.
VDJ at present does not support 4 decks in a single instance.
geposted Mon 07 Jun 10 @ 2:48 pm
It's a multi-purpose unit that has the 'ability' to support 4 USB channels. It does not require 4 USB channels to be useful.
This was already discussed in the General Forum.... topic locked.
geposted Mon 07 Jun 10 @ 5:24 pm
