Hey gang,
Here are some pics of my projector screen I rigged up & am using. The material is 'lycra' swimsuit liner, which has a huge stretch in all directions. Also using the fabric 'alligator' clips with a 2cm-1 inch ring, which are very strong & hold nicely. You can double them up if you need more 'hold' on a particular area. Also got some 'Dollar' store bungees to attach & stretch the screen taught to get rid of any unsightly wrinkles.
The material cost me $50 CDN. Total cost was under $70 CDN.
This material has a slight 'sheen' to it & looks & works great for front or rear projection. I mount my projector on a regular camera tripod & works fantastic as I can adjust the height & angle very easy.
Will post a vid of it also.
geposted Tue 08 Jun 10 @ 2:56 pm
A link to the vid:
http://www.youtube.com/watch?v=CuAcnvU6avg
geposted Tue 08 Jun 10 @ 10:46 pm
Dumb question here, but what is the color.........white, off white?
Thanks for the info and your time
Huey
Huey
geposted Wed 09 Jun 10 @ 12:02 am
It is pure white Huey. Lycra bathing suit liner material.
It's one of the few materials that is all spandex & stretches in ALL directions. There are many fabrics that would do the job, but most also hold wrinkles, which is not a good thing. This also has a slight sheen to it which makes the video look even better.
geposted Wed 09 Jun 10 @ 12:07 am
very nice, thanks for sharing.
geposted Wed 09 Jun 10 @ 8:46 am
